你所需要的
At both sides of the bottom of the screen, there are screw covers. Use a flathead screwdriver to remove them.
Behind each of them will be a screw. Unscrew each screw.
At each corner of the LCD will be one screw to remove. Remove each screw, disconnect the webcam (if applicable), and pull back on the lid.
Separate all of the tape from the back of the LCD screen, and then pull straight back on the cable to remove it from the LCD.
On each side of the LCD, there are three screws holding it. Remove all of them. You're done!
结论
