本指南有最近更改,您可查看未经巡查的最新版本。
简介
The display assembly will need to be replaced if the display itself is damaged, or if its connection to the computer is damaged.
你所需要的
Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
Lift upwards on the back plate to remove it.
Lay the computer down carefully on its keyboard, with the screen open.
There are 5 plastic pins that hold in the upper case cover. With the plastic opening tool, pry downwards on each of the plastic pins to pop them out one at a time.
Flip the computer back over carefully, and remove the loosened upper case.
Flip the computer back over and open the screen. The keyboard will now be loose.
Gently pull towards the screen on both sides of the keyboard and slide it upwards. Set it upside down onto the mousepad area.
Using the plastic opening tool, carefully pry between the black and white portion of the connection. It will pop out with moderate force.
Remove the keyboard.
Using your fingers, carefully pry upwards on the two gold prongs holding in the connection cable, to free it. These are located at the top left side of the case near the display hinge.
Using the plastic opening tool, pry upwards on the port connection for the display cable. It will release with minimal force.
2等其他人完成本指南。
