当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Loosen the seven 6 mm Phillips #0 screws on the back of the case.
Leave all the screws in the back plate and so you don't lose them.
Pull upwards on the top of the back cover to remove it.
Remove the four 9 mm Phillips #0 screws from the cooling assembly.
Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
Gently flip the cooling fan assembly upside-down on the computer surface.
Carefully grab the wire attached to the computer and pull away from the port.
The cooling fan is now safe for removal.
When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
If your unfamiliar with applying thermal paste 如何涂散热膏
取消:我没有完成这个指南。
2等其他人完成本指南。
与5其他贡献者
于04/07/14注册
705 声望
创作了5篇指南
徽章: 11
+ 8更多徽章
CPSU-FORTE-S14S6G2
5 名成员
创作了20篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 15
总计 796
