跳转到主内容
Garmin inReach Explorer Plus LCD Screen Replacement
你所需要的
  1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover.
  3. Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 3 中的图像 1,2 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: 步骤 4 中的图像 1,2 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 5 中的图像 1,2 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 6 中的图像 1,2 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 7 中的图像 1,3 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 7 中的图像 2,3 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,2 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 9 中的图像 1,3 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 9 中的图像 2,3 Garmin inReach Explorer Plus LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
结论
Sean Kelley
于09/28/21注册
387 声望
创作了4篇指南
团队
Clemson, Team 5-4, Hunter Fall 2021 Clemson, Team 5-4, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S5G4
4 名成员
创作了5篇指南
3指南评论
Where do I purchase the replacement LCD screen?
Tyler Lawrence - 回复
Ditto - where can we get a screen??
Ben Wallbank - 回复
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 21
总计 1,437
