简介
The Garmin inReach Explorer Plus is a backcountry GPS device. This guide shows how to remove and replace the Iridium antenna of the Garmin inReach Explorer Plus. The antenna allows the device to connect to satellites to find your location. See our troubleshooting page here for possible symptoms. WARNING: Before disassembling device, make sure that the device is turned off and there are no signs of a swollen battery or shattered glass in the device.
你所需要的
Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
Gently pull out the antenna wire and remove the antenna from the device.
The antenna should now slide out easily. If the antenna is stuck, use the spudger to gently dislodge the antenna from its housing.
