跳转到主内容
加入维修社区 - 创建账户
Garmin Vivoactive Side Button Replacement
你所需要的
  1. Garmin Vivoactive Side Button Replacement, Wristband: 步骤 1 中的图像 1,1
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
  2. Garmin Vivoactive Side Button Replacement: 步骤 2 中的图像 1,2 Garmin Vivoactive Side Button Replacement: 步骤 2 中的图像 2,2
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
  3. Garmin Vivoactive Side Button Replacement, Display Unit: 步骤 3 中的图像 1,1
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
  4. Garmin Vivoactive Side Button Replacement: 步骤 4 中的图像 1,2 Garmin Vivoactive Side Button Replacement: 步骤 4 中的图像 2,2
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
  5. Garmin Vivoactive Side Button Replacement: 步骤 5 中的图像 1,1
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
  6. Garmin Vivoactive Side Button Replacement: 步骤 6 中的图像 1,1
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
  7. Garmin Vivoactive Side Button Replacement: 步骤 7 中的图像 1,1
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
  8. Garmin Vivoactive Side Button Replacement: 步骤 8 中的图像 1,1
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
  9. Garmin Vivoactive Side Button Replacement, Battery: 步骤 9 中的图像 1,2 Garmin Vivoactive Side Button Replacement, Battery: 步骤 9 中的图像 2,2
    • Follow previous guides until you've exposed the battery as shown.
    • Begin by removing the battery connector tab.
    • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
  10. Garmin Vivoactive Side Button Replacement: 步骤 10 中的图像 1,2 Garmin Vivoactive Side Button Replacement: 步骤 10 中的图像 2,2
    • Use a plastic opening pick to gently pry out the battery as shown.
    • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
  11. Garmin Vivoactive Side Button Replacement: 步骤 11 中的图像 1,3 Garmin Vivoactive Side Button Replacement: 步骤 11 中的图像 2,3 Garmin Vivoactive Side Button Replacement: 步骤 11 中的图像 3,3
    • With the battery loose from the case, rotate it to expose the attached tab
    • Gently pry up the attached tab with a fingernail.
    • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
  12. Garmin Vivoactive Side Button Replacement, Motherboard: 步骤 12 中的图像 1,2 Garmin Vivoactive Side Button Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
    • Make an effort not to damage any nearby components of the motherboard with the screwdriver.
  13. Garmin Vivoactive Side Button Replacement: 步骤 13 中的图像 1,2 Garmin Vivoactive Side Button Replacement: 步骤 13 中的图像 2,2
    • Use the spudger to pry up the board from the case.
    • Insert the spudger a minimum distance beneath the board as there are components below.
    • Wiggle the exposed side of the board from each end until it comes free.
    • Use proper electrostatic discharge safety when removing and handling the board.
  14. Garmin Vivoactive Side Button Replacement: 步骤 14 中的图像 1,2 Garmin Vivoactive Side Button Replacement: 步骤 14 中的图像 2,2
    • Remove the GPS antenna by sliding it away from the board.
    • Keep track of the antenna and add it to the new board upon replacement.
  15. Garmin Vivoactive Side Button Replacement, Side Button: 步骤 15 中的图像 1,3 Garmin Vivoactive Side Button Replacement, Side Button: 步骤 15 中的图像 2,3 Garmin Vivoactive Side Button Replacement, Side Button: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    • Orient the crescent shaped retaining clip so the open section faces the bottom of the device.
    • Remove the retaining clip by pulling up away from the device with the precision tweezers.
    • Be careful, the tweezers are quite sharp!
  16. Garmin Vivoactive Side Button Replacement: 步骤 16 中的图像 1,2 Garmin Vivoactive Side Button Replacement: 步骤 16 中的图像 2,2
    • After the retaining clip is removed, the spring and button will pop out.
    • With these very small components free from your device, take care not to lose them.
    • The spring is slightly compressed, so the button may pop out once the clip is removed.
结论
Tessa Gunnin
于10/01/15注册
466 声望
创作了2篇指南
团队
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G21
4 名成员
创作了17篇指南
1指南评论
But where can I get a replacement button?????
Steven Bentley - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 5,830
