简介
The motherboard is one of the most important components of any electronic device. Damage to the motherboard could result for a variety of reasons. Replacing it may be the best option to get your Vivoactive back to running like new.
The Garmin team did a fantastic job backing a lot of punch into this tiny board, some of the most notable components are:
- GPS and GLONASS antenna
- Bluetooth antenna
- Heartbeat Sensor antenna
- Non-Volatile Flash Memory and RAM
If you're having problems with any of these components, you should consider following this replacement guide for a solution.
你所需要的
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Place a heated iOpener over the display to loosen the adhesive.
After about a minute, the iOpener may be removed.
Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
Upon completing this step, the screen should be free from the rest of the device.
Thank you. The repair worked out very well. The tools made it possible. I had cracked the screen and now it is back to being a touch screen.
Follow previous guides until you've exposed the battery as shown.
Begin by removing the battery connector tab.
With the battery loose from the case, rotate it to expose the attached tab
Gently pry up the attached tab with a fingernail.
After reaching step 11, you have to assemble the watch by reversing the steps. But how do you reverse step 3?
How do you glue the watch face on again? What glue do I need to buy?
alan
2等其他人完成本指南。
2条评论
Only <3 months, the motherboard is gone?
Do you have any service shop where I can mail for repairing? I am not going to mail order a motherboard and install by myself every 3 months.
Ming
