跳转到主内容
Garmin Vívoactive 4 Screen Replacement
你所需要的
  1. Garmin Vívoactive 4 Screen Replacement, Watch Band: 步骤 1 中的图像 1,1
    • Flip the watch on its back to reveal the watch band connection pins.
  2. Garmin Vívoactive 4 Screen Replacement, Remove Bands: 步骤 2 中的图像 1,3 Garmin Vívoactive 4 Screen Replacement, Remove Bands: 步骤 2 中的图像 2,3 Garmin Vívoactive 4 Screen Replacement, Remove Bands: 步骤 2 中的图像 3,3
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
  3. Garmin Vívoactive 4 Screen Replacement: 步骤 3 中的图像 1,1
    • With both straps removed, a new replacement watch band may be inserted.
  4. Garmin Vívoactive 4 Screen Replacement, Screen: 步骤 4 中的图像 1,1
    • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
    • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
  5. Garmin Vívoactive 4 Screen Replacement: 步骤 5 中的图像 1,2 Garmin Vívoactive 4 Screen Replacement: 步骤 5 中的图像 2,2
    • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
    • Pry the screen off the device.
    • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
    • Work quickly so the adhesive doesn’t cool too much.
  6. Garmin Vívoactive 4 Screen Replacement: 步骤 6 中的图像 1,3 Garmin Vívoactive 4 Screen Replacement: 步骤 6 中的图像 2,3 Garmin Vívoactive 4 Screen Replacement: 步骤 6 中的图像 3,3
    • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
  7. Garmin Vívoactive 4 Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the screen.
结论
另外一个人完成了本指南。
Jacob Byron
于11/01/23注册
201 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-3, Petersen Fall 2023 UMass Dartmouth, Team 1-3, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 37
过去 30 天: 198
总计 851
