本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Carefully peel the metal bracket away from the battery.
Pull the battery away from the back cover.
Desolder the wires from the speakers using a soldering iron.
Carefully use spudger to pry speakers from outer casing.
Once removed, you may use a soldering iron to remove wires from speakers.
即将完成!
结论
