跳转到主内容
Garmin StreetPilot c330 Speakers Replacement
你所需要的
  1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: 步骤 1 中的图像 1,3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: 步骤 1 中的图像 2,3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: 步骤 1 中的图像 3,3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Speakers Replacement: 步骤 2 中的图像 1,3 Garmin StreetPilot c330 Speakers Replacement: 步骤 2 中的图像 2,3 Garmin StreetPilot c330 Speakers Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Speakers Replacement: 步骤 3 中的图像 1,2 Garmin StreetPilot c330 Speakers Replacement: 步骤 3 中的图像 2,2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Speakers Replacement: 步骤 4 中的图像 1,3 Garmin StreetPilot c330 Speakers Replacement: 步骤 4 中的图像 2,3 Garmin StreetPilot c330 Speakers Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Speakers Replacement: 步骤 5 中的图像 1,1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Speakers Replacement, Battery: 步骤 6 中的图像 1,3 Garmin StreetPilot c330 Speakers Replacement, Battery: 步骤 6 中的图像 2,3 Garmin StreetPilot c330 Speakers Replacement, Battery: 步骤 6 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Speakers Replacement: 步骤 7 中的图像 1,3 Garmin StreetPilot c330 Speakers Replacement: 步骤 7 中的图像 2,3 Garmin StreetPilot c330 Speakers Replacement: 步骤 7 中的图像 3,3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
  8. Garmin StreetPilot c330 Speakers Replacement, Speakers: 步骤 8 中的图像 1,2 Garmin StreetPilot c330 Speakers Replacement, Speakers: 步骤 8 中的图像 2,2
    • Carefully use the spudger to pry the speakers from the outer casing.
    • Once removed, you may use a soldering iron to remove the wires from the speakers.
结论
Michael
于10/07/10注册
107 声望
撰写一个指南
团队
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,733
