跳转到主内容
Garmin Rino 700 Motherboard Replacement
你所需要的
  1. Garmin Rino 700 Motherboard Replacement, Battery Disconnect: 步骤 1 中的图像 1,1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Motherboard Replacement: 步骤 2 中的图像 1,2 Garmin Rino 700 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Motherboard Replacement: 步骤 3 中的图像 1,2 Garmin Rino 700 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Garmin Rino 700 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Motherboard Replacement: 步骤 5 中的图像 1,3 Garmin Rino 700 Motherboard Replacement: 步骤 5 中的图像 2,3 Garmin Rino 700 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
结论
Abigail Dugan
于09/28/21注册
512 声望
创作了5篇指南
团队
Clemson, Team 5-5, Hunter Fall 2021 Clemson, Team 5-5, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S5G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 175
