跳转到主内容
Garmin Nuvi 42LM Screen Replacement
你所需要的
  1. Garmin Nuvi 42LM Screen Replacement, Back Cover: 步骤 1 中的图像 1,3 Garmin Nuvi 42LM Screen Replacement, Back Cover: 步骤 1 中的图像 2,3 Garmin Nuvi 42LM Screen Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Screen Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 42LM Screen Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 42LM Screen Replacement: 步骤 2 中的图像 3,3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Screen Replacement, Motherboard: 步骤 3 中的图像 1,3 Garmin Nuvi 42LM Screen Replacement, Motherboard: 步骤 3 中的图像 2,3 Garmin Nuvi 42LM Screen Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Screen Replacement: 步骤 4 中的图像 1,1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Screen Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 42LM Screen Replacement: 步骤 5 中的图像 2,2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Screen Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 42LM Screen Replacement: 步骤 6 中的图像 2,2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
  7. Garmin Nuvi 42LM Screen Replacement: 步骤 7 中的图像 1,1
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
  8. Garmin Nuvi 42LM Screen Replacement, Screen: 步骤 8 中的图像 1,2 Garmin Nuvi 42LM Screen Replacement, Screen: 步骤 8 中的图像 2,2
    • Push out the screen by pulling back the black clips.
    • The screen is attached to the motherboard and needs to be replaced with it.
结论
2等其他人完成本指南。
一条评论
Where do I purchase the screen for the Nuvi 42LM?
DR ROGER BROWNE - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 468
