跳转到主内容
Garmin Nuvi 370 Microphone Replacement
你所需要的
  1. Garmin Nuvi 370 Microphone Replacement, Microphone: 步骤 1 中的图像 1,1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nuvi 370 Microphone Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 370 Microphone Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nuvi 370 Microphone Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 370 Microphone Replacement: 步骤 3 中的图像 2,2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nuvi 370 Microphone Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 370 Microphone Replacement: 步骤 4 中的图像 2,2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • This step is optional but is recommended as it will create more room to work.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Garmin Nuvi 370 Microphone Replacement: 步骤 5 中的图像 1,1
    • Gently pull out the microphone wire from the terminal. Tweezers are recommended for precision.
  6. Garmin Nuvi 370 Microphone Replacement: 步骤 6 中的图像 1,1
    • The microphone component should now be completely separated from the motherboard.
    • Plug in new, functional microphone component.
终点
Matt West
于04/18/13注册
31 声望
创作了4篇指南
团队
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G65
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 420
