跳转到主内容
加入维修社区 - 创建账户
Disassembling Garmin Nuvi 370 Into Core Components
你所需要的
  1. Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: 步骤 1 中的图像 1,2 Disassembling Garmin Nuvi 370 Into Core Components, Into Core Components: 步骤 1 中的图像 2,2
    • Unscrew the two screws on the antenna unit using a torc-head screwdriver.
    • The Torx-Head Screws' size is T-5, which is about 1.5mm.
    • Gently pry open the antenna unit with your fingers.
    • Be careful and try not to damage the small plastic tab.
  2. Disassembling Garmin Nuvi 370 Into Core Components: 步骤 2 中的图像 1,3 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 2 中的图像 2,3 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Slide out the inner casing attached to the antenna body.
    • Remove the rotating joint connecting the antenna casing to the main device:
    • Squeeze tweezers into the shown location and compress the spring.
    • Lift out the outer casing while keeping the spring compressed.
    • watch out, as the spring loaded portion may fly out unexpectedly.
  3. Disassembling Garmin Nuvi 370 Into Core Components: 步骤 3 中的图像 1,1
    • Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
  4. Disassembling Garmin Nuvi 370 Into Core Components: 步骤 4 中的图像 1,3 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 4 中的图像 2,3 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 4 中的图像 3,3
    • Insert the plastic opening tool into the center of the edge as shown in first picture.
    • Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
  5. Disassembling Garmin Nuvi 370 Into Core Components: 步骤 5 中的图像 1,3 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 5 中的图像 2,3 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 5 中的图像 3,3
    • Detach the front display from the back panel of the device.
  6. Disassembling Garmin Nuvi 370 Into Core Components: 步骤 6 中的图像 1,2 Disassembling Garmin Nuvi 370 Into Core Components: 步骤 6 中的图像 2,2
    • Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts.
    • Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
结论
2等其他人完成本指南。
Robert
于04/19/13注册
80 声望
撰写一个指南
团队
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G65
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 45
总计 1,554
