跳转到主内容
Garmin Nuvi 370 Auxiliary Audio Out Port Replacement
你所需要的
  1. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement, Auxiliary Audio Out Port: 步骤 1 中的图像 1,1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 3 中的图像 2,2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 4 中的图像 2,2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • If nessesary, use tweezers or the spudger for precision.
  5. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    购买
    • De-solder the audio out port. Use a soldering iron to melt the solder on each of the leads of the port and a solder extraction tool (not shown), such as a solder sucker or copper braid.
    • Use tweezers to grab the port for greater protection and precision.
  6. Garmin Nuvi 370 Auxiliary Audio Out Port Replacement: 步骤 6 中的图像 1,1
    • The audio out port should now be completely separated from all other components.
    • Solder new, functional audio port. Make sure all solder connections are clean.
结论
Matt West
于04/18/13注册
31 声望
创作了4篇指南
团队
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G65
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 640
