跳转到主内容
Garmin Nuvi 2589LMT Speaker Replacement
你所需要的
  1. Garmin Nuvi 2589LMT Speaker Replacement, Back Panel Assembly: 步骤 1 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Speaker Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2589LMT Speaker Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Wedge the speaker from the device, using the small plastic opening tool.
    • The speaker is held in place by adhesive tape on the outer rim. Because the speaker is still connected to the motherboard, pry the speaker away from the device gently.
  4. Garmin Nuvi 2589LMT Speaker Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the tape covering the speaker connection to the motherboard.
  5. Garmin Nuvi 2589LMT Speaker Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, desolder the wire connection at the soldering points between the speaker and the motherboard to remove.
    • Learn more about soldering and desoldering connections here.
结论
Adam Ferraro
于10/04/16注册
920 声望
创作了8篇指南
团队
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016 的会员
USFT-NANCE-F16S1G2
4 名成员
创作了8篇指南
一条评论
What size was the speaker in inches or mm? How many ohms was it? Where did you find the replacement?
george.terbush - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 378
