简介
If your device is not turning on, you may need to replace your motherboard. Use this guide to replace a defective motherboard in your Garmin NUVI 2589LMT device. This replacement guide requires more time than replacing the other components in your GPS, since this guide involves soldering.
你所需要的
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
即将完成!
结论
