跳转到主内容
Garmin Nuvi 2589LMT Motherboard Replacement
你所需要的
  1. Garmin Nuvi 2589LMT Motherboard Replacement, Back Panel Assembly: 步骤 1 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
  4. Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using the tweezers, gently pull the ribbon wiring near where it connects to the motherboard to disconnect it from the motherboard.
  5. Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using tweezers, remove the tape covering the speaker connection to the motherboard.
  6. Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a soldering iron, desolder all connections to the motherboard.
    • Learn how to solder and desolder here.
  7. Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 7 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove all 4 of the 4.0 mm screws from the motherboard.
  8. Garmin Nuvi 2589LMT Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using the plastic opening tools gently pry the motherboard away from the case.
结论
Adam Ferraro
于10/04/16注册
920 声望
创作了8篇指南
团队
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016 的会员
USFT-NANCE-F16S1G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 1,988
