跳转到主内容
Garmin Nuvi 255W Logic Board Replacement
你所需要的
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: 步骤 1 中的图像 1,2 Garmin Nuvi 255W Logic Board Replacement, Rear Casing: 步骤 1 中的图像 2,2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: 步骤 2 中的图像 1,1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 255W Logic Board Replacement: 步骤 3 中的图像 2,2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: 步骤 4 中的图像 1,1
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 255W Logic Board Replacement: 步骤 5 中的图像 1,1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 255W Logic Board Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 255W Logic Board Replacement: 步骤 6 中的图像 2,2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: 步骤 7 中的图像 1,2 Garmin Nuvi 255W Logic Board Replacement: 步骤 7 中的图像 2,2
    • Detach the logic board form the battery by pulling out the cable.
结论
另外一个人完成了本指南。
Anjelica
于04/11/10注册
564 声望
创作了3篇指南
团队
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G90
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 10,434
