跳转到主内容
Garmin Nuvi 2455LMT Mother Board Replacement
你所需要的
  1. Garmin Nuvi 2455LMT Mother Board Replacement, Back Panel Assembly: 步骤 1 中的图像 1,1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 3 中的图像 3,3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Mother Board Replacement, Mother Board: 步骤 4 中的图像 1,1
    • Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
    • Hold the GPS with a free hand to ensure stability.
  5. Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Place the screen portion of the GPS face down.
    • Remove the mother board from the plastic back panel.
    • Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
  6. Garmin Nuvi 2455LMT Mother Board Replacement: 步骤 6 中的图像 1,1
    • Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
结论
团队
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 536
