跳转到主内容
Garmin Nüvi 370 Battery Replacement
你所需要的
  1. Garmin Nüvi 370 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nüvi 370 Battery Replacement: 步骤 2 中的图像 1,3 Garmin Nüvi 370 Battery Replacement: 步骤 2 中的图像 2,3 Garmin Nüvi 370 Battery Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nüvi 370 Battery Replacement: 步骤 3 中的图像 1,2 Garmin Nüvi 370 Battery Replacement: 步骤 3 中的图像 2,2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nüvi 370 Battery Replacement: 步骤 4 中的图像 1,2 Garmin Nüvi 370 Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Garmin Nüvi 370 Battery Replacement: 步骤 5 中的图像 1,2 Garmin Nüvi 370 Battery Replacement: 步骤 5 中的图像 2,2
    • Using the flat edge of the spudger from above, gently pry the battery away from the plastic.
  6. Garmin Nüvi 370 Battery Replacement: 步骤 6 中的图像 1,1
    • The battery should now be completely separated from the other components.
    • Insert new, functional battery.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G65
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 1,817
