跳转到主内容
Garmin Edge 530 Back Cover Replacement
你所需要的
  1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: 步骤 1 中的图像 1,1
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
  2. Garmin Edge 530 Back Cover  Replacement: 步骤 2 中的图像 1,3 Garmin Edge 530 Back Cover  Replacement: 步骤 2 中的图像 2,3 Garmin Edge 530 Back Cover  Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
  3. Garmin Edge 530 Back Cover  Replacement: 步骤 3 中的图像 1,3 Garmin Edge 530 Back Cover  Replacement: 步骤 3 中的图像 2,3 Garmin Edge 530 Back Cover  Replacement: 步骤 3 中的图像 3,3
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
  4. Garmin Edge 530 Back Cover  Replacement: 步骤 4 中的图像 1,1
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
  5. Garmin Edge 530 Back Cover  Replacement, Motherboard: 步骤 5 中的图像 1,2 Garmin Edge 530 Back Cover  Replacement, Motherboard: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
  6. Garmin Edge 530 Back Cover  Replacement: 步骤 6 中的图像 1,1
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
  7. Garmin Edge 530 Back Cover  Replacement: 步骤 7 中的图像 1,2 Garmin Edge 530 Back Cover  Replacement: 步骤 7 中的图像 2,2
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
  8. Garmin Edge 530 Back Cover  Replacement: 步骤 8 中的图像 1,3 Garmin Edge 530 Back Cover  Replacement: 步骤 8 中的图像 2,3 Garmin Edge 530 Back Cover  Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
  9. Garmin Edge 530 Back Cover  Replacement, Back Cover: 步骤 9 中的图像 1,1
    • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
    • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
结论
2等其他人完成本指南。
团队
Clemson, Team 2-1, Hunter Spring 2022 Clemson, Team 2-1, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G1
5 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 78
总计 5,012
