跳转到主内容
Game Boy Color Power LED Replacement
你所需要的
  1. Game Boy Color Power LED Replacement, Battery: 步骤 1 中的图像 1,2 Game Boy Color Power LED Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Power LED Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Power LED Replacement, Back Housing: 步骤 3 中的图像 1,1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Power LED Replacement: 步骤 4 中的图像 1,2 Game Boy Color Power LED Replacement: 步骤 4 中的图像 2,2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Power LED Replacement, Motherboard: 步骤 5 中的图像 1,2 Game Boy Color Power LED Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  6. Game Boy Color Power LED Replacement: 步骤 6 中的图像 1,1
    • Gently lift the motherboard from the front housing.
  7. Game Boy Color Power LED Replacement, Power LED: 步骤 7 中的图像 1,2 Game Boy Color Power LED Replacement, Power LED: 步骤 7 中的图像 2,2
  8. Game Boy Color Power LED Replacement: 步骤 8 中的图像 1,1
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
  9. Game Boy Color Power LED Replacement: 步骤 9 中的图像 1,1
    • Solder the leads of the new LED to the circuit board.
  10. Game Boy Color Power LED Replacement: 步骤 10 中的图像 1,1
    • Cut the excess ends of the LED legs using the wire cutters.
结论
7等其他人完成本指南。
Alex Wu
于01/11/13注册
1,446 声望
创作了2篇指南
团队
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G47
4 名成员
创作了56篇指南
6条评论
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - 回复
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith -
and what kind of LED are you using to replace?
Soul Divide - 回复
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - 回复
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 157
总计 17,505
