跳转到主内容
Fusion5 5.5 Gen II Fingerprint Sensor Replacement
你所需要的
  1. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Back Cover: 步骤 1 中的图像 1,2 Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Midframe: 步骤 2 中的图像 1,2 Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Midframe: 步骤 2 中的图像 2,2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 步骤 3 中的图像 1,2 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 步骤 3 中的图像 2,2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Fingerprint Sensor Replacement, Fingerprint Sensor: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
  5. Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 步骤 5 中的图像 1,3 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 步骤 5 中的图像 2,3 Fusion5 5.5 Gen II Fingerprint Sensor Replacement: 步骤 5 中的图像 3,3
    • Using the tweezers, grab the ribbon cable and pull it out from its connector.
    • Remove the fingerprint sensor from its socket on the motherboard.
    • When re-installing the fingerprint sensor, make sure to align the ribbon cable with the plastic socket on the motherboard.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 375
