跳转到主内容
Fujifilm X-M1 LCD Screen Replacement
你所需要的
  1. Fujifilm X-M1 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: 步骤 2 中的图像 1,3 Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: 步骤 2 中的图像 2,3 Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Twist the lens cap to remove it from the camera.
    • Remove the six 6.5 mm Phillips screws from the front of the lens assembly.
    • Use tweezers to remove the top metal ring and the thin metal ring below it .
  3. Fujifilm X-M1 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the four 4.3 mm Phillips screws inside the lens assembly.
  4. Fujifilm X-M1 LCD Screen Replacement, Back Case: 步骤 4 中的图像 1,1
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  5. Fujifilm X-M1 LCD Screen Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  6. Fujifilm X-M1 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  7. Fujifilm X-M1 LCD Screen Replacement: 步骤 7 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  8. Fujifilm X-M1 LCD Screen Replacement: 步骤 8 中的图像 1,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 8 中的图像 2,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  9. Fujifilm X-M1 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  10. Fujifilm X-M1 LCD Screen Replacement: 步骤 10 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  11. Fujifilm X-M1 LCD Screen Replacement: 步骤 11 中的图像 1,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 11 中的图像 2,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 11 中的图像 3,3
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  12. Fujifilm X-M1 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Slide the frame around the LCD to remove it from the camera.
  13. Fujifilm X-M1 LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  14. Fujifilm X-M1 LCD Screen Replacement: 步骤 14 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 14 中的图像 2,2
    • Use tweezers to unhook the speaker near the left handgrip.
  15. Fujifilm X-M1 LCD Screen Replacement: 步骤 15 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 15 中的图像 2,2
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  16. Fujifilm X-M1 LCD Screen Replacement: 步骤 16 中的图像 1,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 16 中的图像 2,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 16 中的图像 3,3
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
  17. Fujifilm X-M1 LCD Screen Replacement, LCD Screen: 步骤 17 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement, LCD Screen: 步骤 17 中的图像 2,2
    • Remove the four 2.6 mm Phillips screws from the LCD hinges.
    • Tilt the LCD away from the metal frame.
    • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
  18. Fujifilm X-M1 LCD Screen Replacement: 步骤 18 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 18 中的图像 2,2
    • Use two fingers to pull the ribbon through the hole in the metal frame.
    • Remove the LCD from the metal frame.
  19. Fujifilm X-M1 LCD Screen Replacement: 步骤 19 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 19 中的图像 2,2
    • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
  20. Fujifilm X-M1 LCD Screen Replacement: 步骤 20 中的图像 1,2 Fujifilm X-M1 LCD Screen Replacement: 步骤 20 中的图像 2,2
    • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
    • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
  21. Fujifilm X-M1 LCD Screen Replacement: 步骤 21 中的图像 1,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 21 中的图像 2,3 Fujifilm X-M1 LCD Screen Replacement: 步骤 21 中的图像 3,3
    • Use a plastic opening tool to pry the LCD case open.
    • Once the case is open, pull the ribbon through the hole on the back case.
  22. Fujifilm X-M1 LCD Screen Replacement: 步骤 22 中的图像 1,1
    • Remove the LCD from the screen cover.
结论
另外一个人完成了本指南。
Kelsea Weber
于11/12/15注册
21,027 声望
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 51
总计 5,707
