跳转到主内容
Fujifilm FinePix Z1 LCD Screen Replacement
你所需要的
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 3 中的图像 1,2 Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 4 中的图像 1,3 Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 4 中的图像 2,3 Fujifilm FinePix Z1 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
结论
Carra
于01/30/18注册
533 声望
创作了4篇指南
团队
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 284
