跳转到主内容
Fujifilm FinePix S8630 Speaker Replacement
你所需要的
  1. Fujifilm FinePix S8630 Speaker Replacement, Battery Door: 步骤 1 中的图像 1,1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Speaker Replacement: 步骤 2 中的图像 1,1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Speaker Replacement: 步骤 4 中的图像 1,2 Fujifilm FinePix S8630 Speaker Replacement: 步骤 4 中的图像 2,2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Speaker Replacement: 步骤 5 中的图像 1,1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Speaker Replacement: 步骤 6 中的图像 1,3 Fujifilm FinePix S8630 Speaker Replacement: 步骤 6 中的图像 2,3 Fujifilm FinePix S8630 Speaker Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Speaker Replacement: 步骤 7 中的图像 1,3 Fujifilm FinePix S8630 Speaker Replacement: 步骤 7 中的图像 2,3 Fujifilm FinePix S8630 Speaker Replacement: 步骤 7 中的图像 3,3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: 步骤 8 中的图像 1,3 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: 步骤 8 中的图像 2,3 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: 步骤 8 中的图像 3,3
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Speaker Replacement, Speaker: 步骤 9 中的图像 1,3 Fujifilm FinePix S8630 Speaker Replacement, Speaker: 步骤 9 中的图像 2,3 Fujifilm FinePix S8630 Speaker Replacement, Speaker: 步骤 9 中的图像 3,3
    • Using your Philips head screwdriver remove the screws from the metal shield.
    • Remove the metal shield.
  10. Fujifilm FinePix S8630 Speaker Replacement: 步骤 10 中的图像 1,3 Fujifilm FinePix S8630 Speaker Replacement: 步骤 10 中的图像 2,3 Fujifilm FinePix S8630 Speaker Replacement: 步骤 10 中的图像 3,3
    • Find the speaker and gently pull away from the motherboard. It is just on by an adhesive.
    • Identify where the speaker is connected to the motherboard and unsolder both of the connections,
    • Guide for Soldering: 如何焊接和拆焊
结论
团队
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S3G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 357
