你所需要的
Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
Using your Philips head screwdriver remove the screws from the metal shield.
Remove the metal shield.
即将完成!
结论
