跳转到主内容
Fujifilm FinePix S4800 Flashbulb Replacement
你所需要的
  1. Fujifilm FinePix S4800 Flashbulb Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 2 中的图像 1,3 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 2 中的图像 2,3 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 2 中的图像 3,3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Flashbulb Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 4 中的图像 1,1
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 5 中的图像 1,1
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 6 中的图像 1,3 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 6 中的图像 2,3 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 6 中的图像 3,3
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 7 中的图像 1,3 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 7 中的图像 2,3 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 8 中的图像 1,2 Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 8 中的图像 2,2
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 Flashbulb Replacement, LCD Screen: 步骤 9 中的图像 1,3 Fujifilm FinePix S4800 Flashbulb Replacement, LCD Screen: 步骤 9 中的图像 2,3 Fujifilm FinePix S4800 Flashbulb Replacement, LCD Screen: 步骤 9 中的图像 3,3
    • At this point, it is highly recommended that you wear an ESD wristband to prevent damage to the internal electronic components.
    • With respect to the camera that was disassembled for this guide, the LCD display easily fell out of its housing after the rear case was removed. If your screen fits more tightly, you can use a plastic removal tool to gently pry up one of the edges of the screen and that will release it from its mount.
    • Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
  10. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 10 中的图像 1,1
    • Lift the screen away from the camera and set it aside.
  11. Fujifilm FinePix S4800 Flashbulb Replacement, Flashbulb: 步骤 11 中的图像 1,1
  12. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 12 中的图像 1,1
    • Use a plastic opening tool to separate the case that covers the flashbulb.
    • The plastic case is fragile, so take your time separating the case.
  13. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 13 中的图像 1,1
    • Unsolder the connections shown in the image that connect the black, pink, white and blue wires to the bulb.
    • Soldering Guide: 如何焊接和拆焊
  14. Fujifilm FinePix S4800 Flashbulb Replacement: 步骤 14 中的图像 1,1
    • Using a pair of ESD-safe tweezers, remove the flashbulb.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S19-G4, Hoffman Spring 2017 USF Tampa, Team S19-G4, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G4
4 名成员
创作了16篇指南
一条评论
If it wasn't for this manual, I don't know how I would have figured it out. I am very lucky to be here
Laker Kolya - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 516
