跳转到主内容
Framework Laptop 16" RAM Replacement
你所需要的
  1. Framework Laptop 16" RAM Replacement, Before you begin: 步骤 1 中的图像 1,2 Framework Laptop 16" RAM Replacement, Before you begin: 步骤 1 中的图像 2,2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
    • Framework recommends that you put your laptop into battery disconnect mode in the BIOS whenever removing the battery. Read how to do that here.
    • To disable this mode, click here.
  2. Framework Laptop 16" RAM Replacement, Unlock the Input Modules: 步骤 2 中的图像 1,3 Framework Laptop 16" RAM Replacement, Unlock the Input Modules: 步骤 2 中的图像 2,3 Framework Laptop 16" RAM Replacement, Unlock the Input Modules: 步骤 2 中的图像 3,3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" RAM Replacement, Remove the touchpad spacers: 步骤 3 中的图像 1,3 Framework Laptop 16" RAM Replacement, Remove the touchpad spacers: 步骤 3 中的图像 2,3 Framework Laptop 16" RAM Replacement, Remove the touchpad spacers: 步骤 3 中的图像 3,3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" RAM Replacement: 步骤 4 中的图像 1,1
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" RAM Replacement, Remove the touchpad: 步骤 5 中的图像 1,3 Framework Laptop 16" RAM Replacement, Remove the touchpad: 步骤 5 中的图像 2,3 Framework Laptop 16" RAM Replacement, Remove the touchpad: 步骤 5 中的图像 3,3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" RAM Replacement, Remove the keyboard: 步骤 6 中的图像 1,3 Framework Laptop 16" RAM Replacement, Remove the keyboard: 步骤 6 中的图像 2,3 Framework Laptop 16" RAM Replacement, Remove the keyboard: 步骤 6 中的图像 3,3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" RAM Replacement, Remove the numpad: 步骤 7 中的图像 1,3 Framework Laptop 16" RAM Replacement, Remove the numpad: 步骤 7 中的图像 2,3 Framework Laptop 16" RAM Replacement, Remove the numpad: 步骤 7 中的图像 3,3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" RAM Replacement, Disconnect the midframe cable: 步骤 8 中的图像 1,2 Framework Laptop 16" RAM Replacement, Disconnect the midframe cable: 步骤 8 中的图像 2,2
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  9. Framework Laptop 16" RAM Replacement, Loosen the midframe screws: 步骤 9 中的图像 1,2 Framework Laptop 16" RAM Replacement, Loosen the midframe screws: 步骤 9 中的图像 2,2
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  10. Framework Laptop 16" RAM Replacement, Remove the midframe: 步骤 10 中的图像 1,2 Framework Laptop 16" RAM Replacement, Remove the midframe: 步骤 10 中的图像 2,2
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  11. Framework Laptop 16" RAM Replacement: 步骤 11 中的图像 1,2 Framework Laptop 16" RAM Replacement: 步骤 11 中的图像 2,2
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  12. Framework Laptop 16" RAM Replacement, Loosen the battery screws: 步骤 12 中的图像 1,2 Framework Laptop 16" RAM Replacement, Loosen the battery screws: 步骤 12 中的图像 2,2
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  13. Framework Laptop 16" RAM Replacement, Remove the battery: 步骤 13 中的图像 1,3 Framework Laptop 16" RAM Replacement, Remove the battery: 步骤 13 中的图像 2,3 Framework Laptop 16" RAM Replacement, Remove the battery: 步骤 13 中的图像 3,3
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  14. Framework Laptop 16" RAM Replacement, Remove the RAM: 步骤 14 中的图像 1,3 Framework Laptop 16" RAM Replacement, Remove the RAM: 步骤 14 中的图像 2,3 Framework Laptop 16" RAM Replacement, Remove the RAM: 步骤 14 中的图像 3,3
    • Push the two metal arms on each side of the RAM stick outward until they disengage and the stick pops up at a shallow angle.
    • Repeat for the other RAM stick.
  15. Framework Laptop 16" RAM Replacement: 步骤 15 中的图像 1,3 Framework Laptop 16" RAM Replacement: 步骤 15 中的图像 2,3 Framework Laptop 16" RAM Replacement: 步骤 15 中的图像 3,3
    • Slide the RAM stick out of its socket and remove it.
    • During reassembly, insert the RAM sticks into their sockets at a slight downward angle, then push down firmly until both metal arms lock the sticks in place.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,515 声望
创作了1,040篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,648篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 69
总计 1,409
