跳转到主内容
Framework Laptop 16" Fingerprint Sensor Replacement
你所需要的
  1. Framework Laptop 16" Fingerprint Sensor Replacement, Before you begin: 步骤 1 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Before you begin: 步骤 1 中的图像 2,2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
    • Framework recommends that you put your laptop into battery disconnect mode in the BIOS whenever removing the battery. Read how to do that here.
    • To disable this mode, click here.
  2. Framework Laptop 16" Fingerprint Sensor Replacement, Unlock the Input Modules: 步骤 2 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Unlock the Input Modules: 步骤 2 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Unlock the Input Modules: 步骤 2 中的图像 3,3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the touchpad spacers: 步骤 3 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the touchpad spacers: 步骤 3 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the touchpad spacers: 步骤 3 中的图像 3,3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 4 中的图像 1,1
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the touchpad: 步骤 5 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the touchpad: 步骤 5 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the touchpad: 步骤 5 中的图像 3,3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the keyboard: 步骤 6 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the keyboard: 步骤 6 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the keyboard: 步骤 6 中的图像 3,3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the numpad: 步骤 7 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the numpad: 步骤 7 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the numpad: 步骤 7 中的图像 3,3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" Fingerprint Sensor Replacement, Disconnect the midframe cable: 步骤 8 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Disconnect the midframe cable: 步骤 8 中的图像 2,2
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  9. Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the midframe screws: 步骤 9 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the midframe screws: 步骤 9 中的图像 2,2
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  10. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the midframe: 步骤 10 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the midframe: 步骤 10 中的图像 2,2
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  11. Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 11 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 11 中的图像 2,2
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  12. Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the battery screws: 步骤 12 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the battery screws: 步骤 12 中的图像 2,2
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  13. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the battery: 步骤 13 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the battery: 步骤 13 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the battery: 步骤 13 中的图像 3,3
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  14. Framework Laptop 16" Fingerprint Sensor Replacement, Lift the interposer door: 步骤 14 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Lift the interposer door: 步骤 14 中的图像 2,2
    • Lift the interposer door by its black pull tab and let it rest upright.
  15. Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the interposer screws: 步骤 15 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the interposer screws: 步骤 15 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the interposer screws: 步骤 15 中的图像 3,3
    • If you have the graphics module installed, your interposer will have four screws. Otherwise, you'll have three screws.
    • Lift the pull tab on the interposer and let it rest vertically to access all of its screws.
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the interposer.
    • If you have the graphics module, use a T5 Torx screwdriver to loosen the four captive screws securing the interposer.
  16. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the interposer: 步骤 16 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the interposer: 步骤 16 中的图像 2,2
    • Lift the interposer by its pull tab and remove it.
  17. Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the expansion bay screws: 步骤 17 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Loosen the expansion bay screws: 步骤 17 中的图像 2,2
    • Use a T5 Torx screwdriver to loosen the two captive screws securing the expansion bay.
    • Close the interposer door before continuing.
  18. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the Expansion Bay module: 步骤 18 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the Expansion Bay module: 步骤 18 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the Expansion Bay module: 步骤 18 中的图像 3,3
    • Slide the Expansion Bay module out of the laptop and remove it.
    • The module should slide out easily. If you feel any resistance, check if the screws holding it in place are fully loosened.
  19. Framework Laptop 16" Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: 步骤 19 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: 步骤 19 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Disconnect the fingerprint sensor: 步骤 19 中的图像 3,3
    • Use the flat end of a spudger, or a clean fingernail, to lift up the locking tab on the fingerprint sensor ZIF connector.
  20. Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 20 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 20 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to grip the blue pull tab and slide the fingerprint sensor cable straight out of its socket.
  21. Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 21 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 21 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 21 中的图像 3,3
    • The fingerprint sensor cable is lightly adhered to the laptop frame.
    • Use your fingers to peel the fingerprint sensor cable away from the frame and separate the adhesive.
    • During reassembly, if your adhesive is still sticky, press the cable to the frame to re-adhere it. Otherwise, use double-sided tape to replace the adhesive.
  22. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the ventilation plate: 步骤 22 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the ventilation plate: 步骤 22 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the ventilation plate: 步骤 22 中的图像 3,3
    • The ventilation plate is held in place with magnets.
    • Lift the bottom of the ventilation plate and pull it away from the laptop until the magnets release.
    • Remove the ventilation plate.
  23. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the fingerprint sensor cover screws: 步骤 23 中的图像 1,2 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the fingerprint sensor cover screws: 步骤 23 中的图像 2,2
    • The fingerprint sensor cover screws are marked 1–3. You don't need to follow this order, but you can use it to help keep track of the screws you've removed.
    • Use a Phillips screwdriver to remove the three 2 mm‑long screws securing the fingerprint sensor cover.
  24. Framework Laptop 16" Fingerprint Sensor Replacement, Remove the fingerprint sensor: 步骤 24 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the fingerprint sensor: 步骤 24 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement, Remove the fingerprint sensor: 步骤 24 中的图像 3,3
    • Use a spudger, or your fingers, to lift the fingerprint sensor cover and remove it.
  25. Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 25 中的图像 1,3 Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 25 中的图像 2,3 Framework Laptop 16" Fingerprint Sensor Replacement: 步骤 25 中的图像 3,3
    • Lift the fingerprint sensor out of its slot in the ventilation plate and remove it.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
于01/16/22注册
213,032 声望
创作了1,040篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,623篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 31
总计 744
