跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 16 Wi-Fi Module Replacement
你所需要的
  1. Framework Laptop 16 Wi-Fi Module Replacement, Before you begin: 步骤 1 中的图像 1,1
    • Unplug all cables and fully shut down your laptop.
  2. Framework Laptop 16 Wi-Fi Module Replacement, Unlock the Input Modules: 步骤 2 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Unlock the Input Modules: 步骤 2 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Unlock the Input Modules: 步骤 2 中的图像 3,3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Spacers: 步骤 3 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Spacers: 步骤 3 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Spacers: 步骤 3 中的图像 3,3
    • Use your fingers to slide the Touchpad Spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the Touchpad Spacer off the laptop and remove it.
  4. Framework Laptop 16 Wi-Fi Module Replacement: 步骤 4 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement: 步骤 4 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement: 步骤 4 中的图像 3,3
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Module: 步骤 5 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Module: 步骤 5 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Touchpad Module: 步骤 5 中的图像 3,3
    • Use your fingers to slide the Touchpad Module toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the Touchpad Module and remove it.
  6. Framework Laptop 16 Wi-Fi Module Replacement, Remove the keyboard: 步骤 6 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the keyboard: 步骤 6 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the keyboard: 步骤 6 中的图像 3,3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard and lift until its magnets release.
    • Remove the keyboard.
  7. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Input Modules: 步骤 7 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Input Modules: 步骤 7 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Input Modules: 步骤 7 中的图像 3,3
    • Your Input Module(s) might be different, but the procedure to remove them is the same.
    • Grip the pull tab at the bottom of the Input Module and lift until its magnets release.
    • Remove the Input Module.
    • Repeat for any remaining Input Modules.
  8. Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Mid Plate cable: 步骤 8 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Mid Plate cable: 步骤 8 中的图像 2,2
    • Grip the black pull tab on the Mid Plate cable press connector.
    • Lift up to disconnect the Mid Plate cable.
  9. Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Mid Plate screws: 步骤 9 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Mid Plate screws: 步骤 9 中的图像 2,2
    • The Mid Plate screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use your Framework Screwdriver to loosen the 16 captive T5 Torx screws securing the Mid Plate.
  10. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Mid Plate: 步骤 10 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Mid Plate: 步骤 10 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Mid Plate: 步骤 10 中的图像 3,3
    • Use your fingers to lift the Mid Plate off the laptop and remove it.
  11. Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Wi-Fi module screw: 步骤 11 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Loosen the Wi-Fi module screw: 步骤 11 中的图像 2,2
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing Wi-Fi module.
    • The module might pop up at a shallow angle when you loosen the screw.
  12. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi module cover: 步骤 12 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi module cover: 步骤 12 中的图像 2,2
    • Slide the clear plastic cover straight off the module and remove it.
  13. Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Wi-Fi module: 步骤 13 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Wi-Fi module: 步骤 13 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Disconnect the Wi-Fi module: 步骤 13 中的图像 3,3
    • While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver under one of the coaxial connectors, where the cable meets the metal head.
    • Lift the screwdriver straight up to disconnect the coaxial cable.
    • Repeat for the other coaxial cable.
  14. Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi Module: 步骤 14 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Remove the Wi-Fi Module: 步骤 14 中的图像 2,2
    • Grip the end of the Wi-Fi Module with the screw hole and slide it out of its socket.
    • Remove the Wi-Fi Module.
  15. Framework Laptop 16 Wi-Fi Module Replacement, Disassembly complete: 步骤 15 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  16. Framework Laptop 16 Wi-Fi Module Replacement, Install the Wi-Fi module: 步骤 16 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Install the Wi-Fi module: 步骤 16 中的图像 2,2
    • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
  17. Framework Laptop 16 Wi-Fi Module Replacement: 步骤 17 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement: 步骤 17 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement: 步骤 17 中的图像 3,3
    • Hold the Wi-Fi module down with your finger.
    • Position the white antenna cable connector over the left Wi-Fi module's coaxial socket.
    • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
    • Tweezers can help position the connector.
    • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
    • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
    • Repeat the procedure with the black antenna cable.
  18. Framework Laptop 16 Wi-Fi Module Replacement: 步骤 18 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement: 步骤 18 中的图像 2,2
    • Slide the clear plastic cover on the module and align its screw with the screw hole cutout.
  19. Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Wi-Fi module screw: 步骤 19 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Wi-Fi module screw: 步骤 19 中的图像 2,2
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing Wi-Fi module.
  20. Framework Laptop 16 Wi-Fi Module Replacement, Place the Mid Plate: 步骤 20 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Place the Mid Plate: 步骤 20 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Place the Mid Plate: 步骤 20 中的图像 3,3
    • Place the Mid Plate on the laptop, making sure it sits evenly on its alignment pegs.
  21. Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Mid Plate screws: 步骤 21 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Tighten the Mid Plate screws: 步骤 21 中的图像 2,2
    • Use your Framework Screwdriver to tighten the 16 captive T5 Torx screws in order (starting with 2) to secure the Mid Plate evenly.
  22. Framework Laptop 16 Wi-Fi Module Replacement, Connect the Mid Plate cable: 步骤 22 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Connect the Mid Plate cable: 步骤 22 中的图像 2,2
    • Align the Mid Plate cable press connector over its socket and press down to connect it.
  23. Framework Laptop 16 Wi-Fi Module Replacement, Install the Input Modules: 步骤 23 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Input Modules: 步骤 23 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Input Modules: 步骤 23 中的图像 3,3
    • Align the top edge of the Input Module with the top edge of the laptop.
    • Lay the Input Module on the laptop and let the magnets pull the keyboard into place
    • Make sure the Input Module is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  24. Framework Laptop 16 Wi-Fi Module Replacement, Install the keyboard: 步骤 24 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Install the keyboard: 步骤 24 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Install the keyboard: 步骤 24 中的图像 3,3
    • Align the top edge of the keyboard with the top edge of the laptop.
    • Lay the keyboard on the laptop and let the magnets pull the keyboard into place
    • Make sure the keyboard is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  25. Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Module: 步骤 25 中的图像 1,2 Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Module: 步骤 25 中的图像 2,2
    • Place the Touchpad Module flat on its cutout so its clips are properly aligned.
    • Press the Touchpad Module down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  26. Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Spacers: 步骤 26 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Spacers: 步骤 26 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Install the Touchpad Spacers: 步骤 26 中的图像 3,3
    • Place the Touchpad Spacer over its spot on the laptop with the bottom edge overhanging slightly.
    • Slide the Touchpad Spacer towards the top of the laptop to secure it.
    • Repeat the same procedure for the other Touchpad Spacer.
  27. Framework Laptop 16 Wi-Fi Module Replacement, Lock the Input Modules: 步骤 27 中的图像 1,3 Framework Laptop 16 Wi-Fi Module Replacement, Lock the Input Modules: 步骤 27 中的图像 2,3 Framework Laptop 16 Wi-Fi Module Replacement, Lock the Input Modules: 步骤 27 中的图像 3,3
    • Push the Input Module latches back into place to lock them.
结论
If you need help, contact Framework support.
Alex Diaz-Kokaisl
于01/16/22注册
218,494 声望
创作了1,087篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 45
总计 192
