跳转到主内容
FoodSaver V4980 Bag Cutter Replacement
  1. FoodSaver V4980 Bag Cutter Replacement, Bag Cutter: 步骤 1 中的图像 1,1
    • The bag cutter is a small plastic rolling apparatus in the bag cutter arm.
    • Lift up the top cover to get to the bag cutter arm.
  2. FoodSaver V4980 Bag Cutter Replacement: 步骤 2 中的图像 1,2 FoodSaver V4980 Bag Cutter Replacement: 步骤 2 中的图像 2,2
    • Pull the sides of the cutter arm apart, and pull on the bag cutter to remove it from the arm.
结论
团队
Cal Poly, Team 34-17, Maness Spring 2016 Cal Poly, Team 34-17, Maness Spring 2016 的会员
CPSU-MANESS-S16S34G17
4 名成员
创作了6篇指南
3条评论
how do i get a new one
Darlene Paulson - 回复
my bag cutter dont cut how do i get a new one & how much
my MACHINE IS BRAND NE, FIRST USE AND IT WILL NOT CUT
James Budelman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 3,447
