跳转到主内容
加入维修社区 - 创建账户
Fast Fix Extension cord Repair
你所需要的
  1. Fast Fix Extension cord Repair, Extension cord Repair: 步骤 1 中的图像 1,1
    • Repairing an extension cord is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut the cable and expose the interior wires.
  2. Fast Fix Extension cord Repair: 步骤 2 中的图像 1,2 Fast Fix Extension cord Repair: 步骤 2 中的图像 2,2
    • Use wire strippers to remove about 5cm of the outer insulation from the cable.
    • Remove around a centimeter of insulation from the inner wires to reveal the bare copper using the wire strippers.
    • Do the same for the other side of the extension cord.
  3. Fast Fix Extension cord Repair: 步骤 3 中的图像 1,1
    • Take the two halves of the extension and join the corresponding wires together. Neutral wire N (blue wire); The phase L wire (red, black or brown); The ground wire (green and yellow).
    • Twist the copper wires together.
  4. Fast Fix Extension cord Repair: 步骤 4 中的图像 1,3 Fast Fix Extension cord Repair: 步骤 4 中的图像 2,3 Fast Fix Extension cord Repair: 步骤 4 中的图像 3,3
    • Solder the joints of the wires with a soldering gun.
    • For help with soldering, check out our How to Solder and Desolder Connections guide.
    • It may help to use a vice grip or similar to hold one end of the wires in place, so that you can manipulate the other side with your hands.
    • If necessary, you can rectify any blisters or spikes in the soldering using a small hammer.
    • Once you've soldered all of the connections, check with the ohmmeter that the current flows well from one end of the extension cord to the other. If it does not, check to make sure that the solder has made a firm connection with each side of each cable pair. It may help to reflow the soldered connections.
  5. Fast Fix Extension cord Repair: 步骤 5 中的图像 1,1
    • Use electrical tape to insulate each of the inner wires.
  6. Fast Fix Extension cord Repair: 步骤 6 中的图像 1,1
    • After covering all connections individually with electrical tape. Then cover the entire wire harness with retractable sheath thermosetting tube.
    • Apply heat from a hairdryer or heat gun to the heat shrink tubing until it is wrapped tightly around the cable.
  7. Fast Fix Extension cord Repair: 步骤 7 中的图像 1,1
    • This is how your extension cord will look like after you finished to repair it.
终点
3等其他人完成本指南。
Belgony Nsimba
于05/05/20注册
208 声望
撰写一个指南
团队
UW Tacoma, Team S16-G16, Cardinal Spring 2020 UW Tacoma, Team S16-G16, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S16G16
1 名成员
创作了3篇指南
1指南评论
Be sure to slide the section of thermosetting tube onto one of the cord ends before soldering the wires. The tube should be cut to a length that will cover the repair section and overlap the adjacent outer insulation by 1.5cm on each side of the repair. After soldering, slide the tube over the repair and heat shrink it.
lw3685 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 181
总计 18,698
