简介
Use this guide to replace the earpiece speaker in your Fairphone 4.
你所需要的
Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lift the battery out of its recess and remove it.
Remove the battery.
Insert an opening pick beneath the cover near the triangular mark.
Twist the opening pick to pry the cover up.
Remove the cover.
Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
Use a spudger to disconnect the earpiece speaker by prying the connector straight up from its socket.
Use a spudger to lift the earpiece speaker so you can grab it.
Remove the earpiece speaker.
