跳转到主内容
加入维修社区 - 创建账户
Fairphone 3 Rear Camera Module Replacement
你所需要的
  1. Fairphone 3 Rear Camera Module Replacement, Back Cover: 步骤 1 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    询问修复机器人
    添加评论
  2. Fairphone 3 Rear Camera Module Replacement: 步骤 2 中的图像 1,3 Fairphone 3 Rear Camera Module Replacement: 步骤 2 中的图像 2,3 Fairphone 3 Rear Camera Module Replacement: 步骤 2 中的图像 3,3
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    询问修复机器人
    添加评论
  3. Fairphone 3 Rear Camera Module Replacement, Battery: 步骤 3 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    询问修复机器人
    添加评论
  4. Fairphone 3 Rear Camera Module Replacement: 步骤 4 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
    询问修复机器人
    添加评论
  5. Fairphone 3 Rear Camera Module Replacement, Display Assembly: 步骤 5 中的图像 1,1
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    添加评论
  6. Fairphone 3 Rear Camera Module Replacement: 步骤 6 中的图像 1,3 Fairphone 3 Rear Camera Module Replacement: 步骤 6 中的图像 2,3 Fairphone 3 Rear Camera Module Replacement: 步骤 6 中的图像 3,3
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    添加评论
  7. Fairphone 3 Rear Camera Module Replacement: 步骤 7 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement: 步骤 7 中的图像 2,2
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    添加评论
  8. Fairphone 3 Rear Camera Module Replacement: 步骤 8 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
    询问修复机器人
    添加评论
  9. Fairphone 3 Rear Camera Module Replacement: 步骤 9 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement: 步骤 9 中的图像 2,2
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    添加评论
  10. Fairphone 3 Rear Camera Module Replacement, Rear Camera Module: 步骤 10 中的图像 1,1
    • Remove the two 4.1mm-long Phillips #00 screws.
    询问修复机器人
    添加评论
  11. Fairphone 3 Rear Camera Module Replacement: 步骤 11 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the camera connecting cable.
    询问修复机器人
    添加评论
  12. Fairphone 3 Rear Camera Module Replacement: 步骤 12 中的图像 1,2 Fairphone 3 Rear Camera Module Replacement: 步骤 12 中的图像 2,2
    • Use a spudger to pry up the rear camera module.
    询问修复机器人
    添加评论
  13. Fairphone 3 Rear Camera Module Replacement: 步骤 13 中的图像 1,1
    • Remove the rear camera module.
    添加评论
结论
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
取消:我没有完成这个指南。
18等其他人完成本指南。
Adriana Zwink
于12/18/19注册
67,717 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了30,155篇指南
3指南评论
How NOT to remove the display!
I just destroyed my display module a bit and had to fix it with glue. :(
This works better: https://www.youtube.com/watch?v=wGTYZNzg...
caroline - 回复 分享
I think this guide should mention that the camera connecting cable can become disconnected accidentally on its other end (under the metallic cover) which is easy to miss. This forum post helped me: https://forum.fairphone.com/t/be-careful...
The metallic cover can be removed easily after screwing off two Torx screws. Couple of people on the forum experienced this and it helped me solve my problem.
cmur2 - 回复 分享
Pas de problème pour changer le module. Les explications données par ifixit sont claires et aisées à suivre.
Eric Beaucarne - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 78
总计 9,828
