跳转到主内容
Fairphone 2 Display Assembly Replacement
你所需要的
  1. Fairphone 2 Display Assembly Replacement, Slim Case: 步骤 1 中的图像 1,3 Fairphone 2 Display Assembly Replacement, Slim Case: 步骤 1 中的图像 2,3 Fairphone 2 Display Assembly Replacement, Slim Case: 步骤 1 中的图像 3,3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Display Assembly Replacement: 步骤 2 中的图像 1,3 Fairphone 2 Display Assembly Replacement: 步骤 2 中的图像 2,3 Fairphone 2 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the front part of the slim case.
  4. Fairphone 2 Display Assembly Replacement, Battery: 步骤 4 中的图像 1,3 Fairphone 2 Display Assembly Replacement, Battery: 步骤 4 中的图像 2,3 Fairphone 2 Display Assembly Replacement, Battery: 步骤 4 中的图像 3,3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
  5. Fairphone 2 Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 1,3 Fairphone 2 Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 2,3 Fairphone 2 Display Assembly Replacement, Display Assembly: 步骤 5 中的图像 3,3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    • Another possible way of sliding the display assembly open.
  6. Fairphone 2 Display Assembly Replacement: 步骤 7 中的图像 1,1
    • Take off the display assembly.
结论
37等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
109,704 声望
创作了188篇指南
团队
iFixit iFixit 的会员
Community
141 名成员
创作了17,725篇指南
7条评论
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Oriane Petit - 回复
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Christian Rapp - 回复
Ich habe keine blauen Schalter, ich rede vom FP 1U, ist das korrekt?
Birgit - 回复
FP 1U: Ich habe keine blauen Schalter.....
Birgit - 回复
The Display seem to be stuck completely, any tips on how to move it?
siohdk - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 40
总计 17,020
