跳转到主内容
加入维修社区 - 创建账户
Fairphone 2 Battery Replacement
你所需要的
  1. Fairphone 2 Battery Replacement, Slim Case: 步骤 1 中的图像 1,3 Fairphone 2 Battery Replacement, Slim Case: 步骤 1 中的图像 2,3 Fairphone 2 Battery Replacement, Slim Case: 步骤 1 中的图像 3,3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Battery Replacement: 步骤 2 中的图像 1,3 Fairphone 2 Battery Replacement: 步骤 2 中的图像 2,3 Fairphone 2 Battery Replacement: 步骤 2 中的图像 3,3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the front part of the slim case.
  4. Fairphone 2 Battery Replacement, Battery: 步骤 4 中的图像 1,3 Fairphone 2 Battery Replacement, Battery: 步骤 4 中的图像 2,3 Fairphone 2 Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
结论
10等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
130,671 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,145篇指南
1指南评论
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
Jim Kinnibrugh - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 63
总计 133,554
