跳转到主内容
Fahrenheit FHT 125PRMR Motherboard Replacement
你所需要的
  1. Fahrenheit FHT 125PRMR Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove both hinge covers on each side of the flat iron.
  2. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using Philips head #2 remove the 7 mm black screw that was underneath one of the hinge covers.
  3. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 3 中的图像 1,2 Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 3 中的图像 2,2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 4 中的图像 1,2 Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using Philips head #1 remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using Philips head #1 remove the two 4 mm silver screws on the sides of dial panel cover.
  6. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 6 中的图像 1,2 Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using Philips head #00 to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 8 中的图像 1,2 Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove three 3 mm sliver screws #1 from the motherboard.
    • Use your hand to life the motherboard out of the flat iron.
  9. Fahrenheit FHT 125PRMR Motherboard Replacement: 步骤 9 中的图像 1,1
    • Desolder the two white, one red, and one black cables from the mother board to remove all connection to the flat iron.
    • 如何焊接和拆焊
结论
MeKenzie Hilsmeyer
于09/29/16注册
23 声望
撰写一个指南
团队
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S2G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,539
