跳转到主内容
加入维修社区 - 创建账户
Eureka EasyClean 71C Power Cord Replacement
你所需要的
  1. Eureka EasyClean 71C Power Cord Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Power Cord Replacement: 步骤 2 中的图像 1,1
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Power Cord Replacement: 步骤 3 中的图像 1,1
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Power Cord Replacement: 步骤 4 中的图像 1,2 Eureka EasyClean 71C Power Cord Replacement: 步骤 4 中的图像 2,2
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Eureka EasyClean 71C Power Cord Replacement, Casing: 步骤 5 中的图像 1,1
    • Pull the power switch all the way up and remove the dust cup.
  6. Eureka EasyClean 71C Power Cord Replacement: 步骤 6 中的图像 1,2 Eureka EasyClean 71C Power Cord Replacement: 步骤 6 中的图像 2,2
    • Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
    • Pull the casing apart.
  7. Eureka EasyClean 71C Power Cord Replacement, Power Cord: 步骤 7 中的图像 1,1
    • Pull out the switch board.
    • Ensure the vacuum is powered off and unplugged before handling any electronics.
  8. Eureka EasyClean 71C Power Cord Replacement: 步骤 8 中的图像 1,2 Eureka EasyClean 71C Power Cord Replacement: 步骤 8 中的图像 2,2
    • Desolder the highlighted black and white wires.
    • For instructions on how to solder and desolder wires, visit this guide.
  9. Eureka EasyClean 71C Power Cord Replacement: 步骤 9 中的图像 1,1
    • Unscrew the 22.3mm PH2 Phillips head screw.
    • Remove the power cord.
结论
Tanner Durnil
于11/06/17注册
631 声望
创作了6篇指南
团队
IUPUI, Team S6-G4, Baechle Fall 2017 IUPUI, Team S6-G4, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S6G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 518
