跳转到主内容
Euhomy IM-06D Power Supply Cable Replacement
你所需要的
  1. Euhomy IM-06D Power Supply Cable Replacement, Fan: 步骤 1 中的图像 1,1
    • Rotate the device so that the screws on the bottom are visible.
    • Remove the two 15 mm Phillips screws.
    • Remove the two 10 mm Phillips screws.
  2. Euhomy IM-06D Power Supply Cable Replacement: 步骤 2 中的图像 1,2 Euhomy IM-06D Power Supply Cable Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the device.
  3. Euhomy IM-06D Power Supply Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the two 10 mm Phillips screws that secure the fan.
  4. Euhomy IM-06D Power Supply Cable Replacement: 步骤 4 中的图像 1,2 Euhomy IM-06D Power Supply Cable Replacement: 步骤 4 中的图像 2,2
    • Remove the cover plate.
  5. Euhomy IM-06D Power Supply Cable Replacement: 步骤 5 中的图像 1,2 Euhomy IM-06D Power Supply Cable Replacement: 步骤 5 中的图像 2,2
    • Snip the zip tie holding the wires together.
    • Unplug the wire from the board.
    • Remove the fan from the device.
  6. Euhomy IM-06D Power Supply Cable Replacement, Power Supply Cable: 步骤 6 中的图像 1,1
    • Follow the green ground wire and remove the 15 mm screw securing it with a Phillips screwdriver.
  7. Euhomy IM-06D Power Supply Cable Replacement: 步骤 7 中的图像 1,2 Euhomy IM-06D Power Supply Cable Replacement: 步骤 7 中的图像 2,2
    • Remove the Phillips screw holding the power cable in place.
  8. Euhomy IM-06D Power Supply Cable Replacement: 步骤 8 中的图像 1,2 Euhomy IM-06D Power Supply Cable Replacement: 步骤 8 中的图像 2,2
    • Follow the white wire and unplug it from the motherboard.
    • Follow the black wire and disconnect it from the motherboard.
    • Remove the power supply cable.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
另外一个人完成了本指南。
Joel Mello
于03/21/25注册
415 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-5, Botvin Spring 2025 UMass Dartmouth, Team 2-5, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 88
