跳转到主内容
Euhomy IM-06D Compressor Relay Replacement
你所需要的
  1. Euhomy IM-06D Compressor Relay Replacement, Fan: 步骤 1 中的图像 1,1
    • Rotate the device so that the screws on the bottom are visible.
    • Remove the two 15 mm Phillips screws.
    • Remove the two 10 mm Phillips screws.
  2. Euhomy IM-06D Compressor Relay Replacement: 步骤 2 中的图像 1,2 Euhomy IM-06D Compressor Relay Replacement: 步骤 2 中的图像 2,2
    • Remove the back panel from the device.
  3. Euhomy IM-06D Compressor Relay Replacement: 步骤 3 中的图像 1,1
    • Remove the two 10 mm Phillips screws that secure the fan.
  4. Euhomy IM-06D Compressor Relay Replacement: 步骤 4 中的图像 1,2 Euhomy IM-06D Compressor Relay Replacement: 步骤 4 中的图像 2,2
    • Remove the cover plate.
  5. Euhomy IM-06D Compressor Relay Replacement: 步骤 5 中的图像 1,2 Euhomy IM-06D Compressor Relay Replacement: 步骤 5 中的图像 2,2
    • Snip the zip tie holding the wires together.
    • Unplug the wire from the board.
    • Remove the fan from the device.
  6. Euhomy IM-06D Compressor Relay Replacement, Compressor Relay: 步骤 6 中的图像 1,3 Euhomy IM-06D Compressor Relay Replacement, Compressor Relay: 步骤 6 中的图像 2,3 Euhomy IM-06D Compressor Relay Replacement, Compressor Relay: 步骤 6 中的图像 3,3
    • Locate the black box under the green ground cable and find the silver clip running across the back of it.
    • Use a pry tool remove the clip.
    • Remove the box.
  7. Euhomy IM-06D Compressor Relay Replacement: 步骤 7 中的图像 1,3 Euhomy IM-06D Compressor Relay Replacement: 步骤 7 中的图像 2,3 Euhomy IM-06D Compressor Relay Replacement: 步骤 7 中的图像 3,3
    • Locate the white wire and black relay.
    • Using your hands pull the wire and relay out of the compressor.
    • Once the relay and white wire have been removed you're ready to replace it with your new part.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
另外一个人完成了本指南。
Brady C
于03/21/25注册
219 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-5, Botvin Spring 2025 UMass Dartmouth, Team 2-5, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 153
