简介
Smartphone batteries will naturally degrade as you use your phone more and more. This will cause the battery life to be shorter than it was when you first started using the phone. Use this guide to replace your Essential Phone battery or to remove it to access other components of the phone.
Note: A verified replacement battery for the Essential Phone is currently hard to find, so keep that in mind when performing a battery replacement.
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Heat the perimeter of the display to soften the adhesive securing it.
If available, use a hot plate or heat pad. Place the Essential Phone face-down and heat it to 85° C for at least 15 minutes.
Otherwise, use a heat gun to evenly heat the entire perimeter of the display until it's too hot to touch. Try to maintain a high temperature for 15-20 minutes—but beware that without exact control over the temperature, you can easily destroy the display.
Use the point of a spudger to pry the display cable pop connector straight up from its socket.
Use a Phillips #000 driver to remove the six 3.4mm screws holding on the back panel.
9等其他人完成本指南。
3条评论
Is more glue needed when the display is put back in? The guide doesn’t mention that process.
Yes when you re-install the display you’ll need to add more adhesive as it destroy it during the removal process. They recommend using '''Tesa 61395 Tape (1mm)''' however I got away with using 2mm tape as it was all I had on hand and it worked just fine, however the application was a little difficult. I’d also recommend getting some small conductive tape for the display adhesive pads as well as the couple of conductive pads on the bottom of the battery.
Justin W -
can you also do the putting it back guide pls
