当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Push the tab in with one of the plastic opening tools.
Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
Repeat this process with the furthermost right tab, then proceed with the middle tab.
这个步骤还没有翻译 帮忙翻译一下
The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer.
The release points for the tabs are located in holes on the depressed area of the base (darker piece).
Use the pointed end of a spudger to pry out the tab.
Use one of the plastic tools to keep the tab pried out. Once it releases, push in towards the printer (viewing from the side) and pull up on the case.
这个步骤还没有翻译 帮忙翻译一下
All of the tabs have now been released.
When trying to completely remove the cover, it gets caught on these two back components. Maneuvering around these can be tricky.
Push the cover to the right slightly and then push it backwards (out of the screen in this picture). This should give it some wiggle room. Repeat this as necessary.
