跳转到主内容
Epson PowerLite 77c Top Panel Replacement
你所需要的
  1. Epson PowerLite 77c Top Panel Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Top Panel Replacement: 步骤 2 中的图像 1,2 Epson PowerLite 77c Top Panel Replacement: 步骤 2 中的图像 2,2
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
结论
Connor Bassolino
于03/29/22注册
17,650 声望
创作了76篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 93
