跳转到主内容
Epson PowerLite 77c Button Panel Replacement
你所需要的
  1. Epson PowerLite 77c Button Panel Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Button Panel Replacement: 步骤 2 中的图像 1,2 Epson PowerLite 77c Button Panel Replacement: 步骤 2 中的图像 2,2
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  3. Epson PowerLite 77c Button Panel Replacement, Button Panel: 步骤 3 中的图像 1,1
    • On the underside of the top panel, use a Phillips #0 to remove the four screws securing the button panel.
  4. Epson PowerLite 77c Button Panel Replacement: 步骤 4 中的图像 1,1
    • Remove the button panel.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 163
