跳转到主内容
Epson PictureMate Pal PM 200 Display Replacement
你所需要的
  1. Epson PictureMate Pal PM 200 Display Replacement, Printer Top Plate: 步骤 1 中的图像 1,3 Epson PictureMate Pal PM 200 Display Replacement, Printer Top Plate: 步骤 1 中的图像 2,3 Epson PictureMate Pal PM 200 Display Replacement, Printer Top Plate: 步骤 1 中的图像 3,3
    • Be certain that device is powered off and unplugged as to not damage any of the internal components before beginning.
    • Power off device and use a metal spudger to remove each of the two caps over the screws that hold the top plate to the device.
  2. Epson PictureMate Pal PM 200 Display Replacement: 步骤 2 中的图像 1,1
    • Remove the two 6 mm Phillips screws.
  3. Epson PictureMate Pal PM 200 Display Replacement: 步骤 3 中的图像 1,2 Epson PictureMate Pal PM 200 Display Replacement: 步骤 3 中的图像 2,2
    • Gently lift the lid and turn it to face the daughterboard underneath.
    • Gently pull the no-fuss ribbon cable out from its connector.
    • The other end of the ribbon cable is still in the device's motherboard. Only remove the end connected to the daughterboard unless stated in a later step in order to not lose it due to unnecessary removal.
  4. Epson PictureMate Pal PM 200 Display Replacement: 步骤 4 中的图像 1,2 Epson PictureMate Pal PM 200 Display Replacement: 步骤 4 中的图像 2,2
    • Remove the printer top plate.
  5. Epson PictureMate Pal PM 200 Display Replacement, Display: 步骤 5 中的图像 1,1
    • Set the panel to the side on a neat, flat surface.
  6. Epson PictureMate Pal PM 200 Display Replacement: 步骤 6 中的图像 1,3 Epson PictureMate Pal PM 200 Display Replacement: 步骤 6 中的图像 2,3 Epson PictureMate Pal PM 200 Display Replacement: 步骤 6 中的图像 3,3
    • Remove the two 8 mm Phillips screws securing the display assembly to the top panel.
  7. Epson PictureMate Pal PM 200 Display Replacement: 步骤 7 中的图像 1,2 Epson PictureMate Pal PM 200 Display Replacement: 步骤 7 中的图像 2,2
    • Pull the black ZIF locking flap toward the ribbon cable.
    • Disconnect the ribbon cable from the daughterboard.
  8. Epson PictureMate Pal PM 200 Display Replacement: 步骤 8 中的图像 1,2 Epson PictureMate Pal PM 200 Display Replacement: 步骤 8 中的图像 2,2
    • Remove the display assembly from the top panel.
  9. Epson PictureMate Pal PM 200 Display Replacement: 步骤 9 中的图像 1,2 Epson PictureMate Pal PM 200 Display Replacement: 步骤 9 中的图像 2,2
    • Remove the two 8 mm screws that secure the display to the housing.
  10. Epson PictureMate Pal PM 200 Display Replacement: 步骤 10 中的图像 1,3 Epson PictureMate Pal PM 200 Display Replacement: 步骤 10 中的图像 2,3 Epson PictureMate Pal PM 200 Display Replacement: 步骤 10 中的图像 3,3
    • Remove the display from the housing.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andre
于03/31/25注册
484 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-4, Botvin Spring 2025 UMass Dartmouth, Team 2-4, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G4
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 90
