跳转到主内容
Envizen V100M Speakers Replacement
你所需要的
  1. Envizen V100M Speakers Replacement, Back Cover: 步骤 1 中的图像 1,2 Envizen V100M Speakers Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Speakers Replacement: 步骤 2 中的图像 1,3 Envizen V100M Speakers Replacement: 步骤 2 中的图像 2,3 Envizen V100M Speakers Replacement: 步骤 2 中的图像 3,3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Speakers Replacement, Speakers: 步骤 3 中的图像 1,1
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. Envizen V100M Speakers Replacement: 步骤 4 中的图像 1,1
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Envizen V100M Speakers Replacement: 步骤 5 中的图像 1,1
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
结论
nbach
于03/23/15注册
663 声望
创作了6篇指南
团队
UMass Dartmouth, Team 3-2, Duarte Spring 2015 UMass Dartmouth, Team 3-2, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 119
