简介
If your tablet will not connect to wifi, even after you have reset the router, you can use this guide to replace the wifi antenna. You should be able to easily identify which part this is, as it is a long wire attached to the motherboard. You will need tools such as a Phillips Head screwdriver with a #00 3mm screw, a spudger, plastic opening tool, as well as a soldering iron to complete the job.
你所需要的
Desolder the connections to remove the antenna.
Refer to the soldering technique guide.
即将完成!
结论
