跳转到主内容
Ematic FunTab 3 Speaker Replacement
你所需要的
  1. Ematic FunTab 3 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,3 Ematic FunTab 3 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,3 Ematic FunTab 3 Speaker Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Speaker Replacement: 步骤 2 中的图像 1,1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Ematic FunTab 3 Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
  4. Ematic FunTab 3 Speaker Replacement: 步骤 4 中的图像 1,3 Ematic FunTab 3 Speaker Replacement: 步骤 4 中的图像 2,3 Ematic FunTab 3 Speaker Replacement: 步骤 4 中的图像 3,3
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
结论
Amanda Davis
于07/11/18注册
581 声望
创作了5篇指南
团队
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 258
